Hi
heaningw
Hi new members Bill and Mary. How do you access the water pump on a 3051s Forester. It is in a basement compartment behind a door. How to change it
On the passenger side, compartment just behind the rear tires there should be a panel with a latch that swings down when open.
Water pump should be behind that door.
There are screws in the panel at the back of the compartment as well you can remove them take the whole cover out.
Should be readily accessible once that stuff is out of the way.
Unless they moved it compared to our 2014 we had
Welcome to RVForums.com!
Thanks, that's a big help.
Quite welcome and welcome to the forum.
Had a 3051S for just under six years and lots of other good people here for any questions.
Welcome to the group. Good luck on the water pump.
