Hitch drop length 2023 Vacationer
patwcon01
We just purchased a 2023 Holiday rambler vacationer. We tow a jeep with a blue ox set up. Our trade in was much lower to the ground. Can anyone help with the dimensions for a hitch drop down? Thank you. Pat can Kathy
You'll need to measure for yourself with the coach loaded for travel with your specific coach/tow bar and vehicle. There are many different models of blue ox tow bar, many different jeeps and base plates... not only that but your coach loaded for travel may not sit the same as the same coach loaded for travel by someone else.
Make sure to consult the tow bar manual as far as how level the tow bar needs to be, typically they'll specify within 'x' inches of level.
I have the BlueOx Avail tow bar. My Jeep is level with a 4in drop on the hitch. The isn't supposed to be more than a 3in difference. I measured the base plate on the Jeep and the hitch on the MH (on level ground). Surprisingly no change from old MH.
