2017 Windsport. Hot water is just barely warm enough to shower in with no cold mixed in at all on Propane. When we got it last year I remember it hot enough for the need to mix in some cold. This is on city connection. Last shower before we got home was on the pump and was warmer but still no need to mix in cold. The toggle for 110 electric heat doesn't seem to do much of anything. Is the electric suppose to work the hot water tank as well as Propane if everything is functioning correctly or is it just supplemental until the Propane is turned on? Also could I have messed up De-winterizing and water is getting cool before it gets to the shower? I don't know where else it would flow to, only valves I've ever turned are the tank bypass valves, just a thought. Showers were a little warmer in 90+ heat in KY than they were in Stugis last week. I wouldn't think ambient temp could make a noticeable difference but who knows. Why would it be warmer through the pump on fresh water? Thanks for any help!
