Question How Often To Sanitize?
jmltech
RVF VIP
Salida, CO
Winnebago
24V Navion
Mercedes Benz
2017 Jeep Wrangler Sahara
Was curious as to how often owners sanitize their water storage tank?
We are getting ready to take a 5 day road trip. I last sanitized in July, filling the 60 gallon with a cup of bleach, and letting it sit for a couple of hours after turning on the faucets for a few minutes.
There is currently about a 1/3 of water that has been sitting in the tank since July. I am considering dumping the water and re-sanitizing.
Is this mostly a judgment call?
Thanks all,
Joe
For us, any time water sits in the FW tank, unused, for more than a month, we sanitize. Rather than using bleach, however, we prefer Thetford Fresh Water Tank Sanitizer.
https://www.amazon.com/dp/B001TIV1KA/?tag=rvf01-20
It doesn't leave the residual chlorine taste...because it isn't chlorine-based.
When we are on the road with the coach, we use water from the FW tank and refill rather than using directly from the park supply.
I do it once a year, at the beginning of the season. Every 2-3 weeks I run the fw tank down to 1/3 and refill.
As a full timer, our water is not in the tank more than a day or two, but we still sanitize once a year.
if I were storing I’d probably sanitize before and after storage.
I bought the stuff, probably should use it. When I anchor down at Palmcatraz mid February I'll probably get it done.
sooooo, How do you refill it?
I agree with TJ we would sanitize our tank anytime it’s been sitting for more than a ....month, I agree.
I believe he is saying he refills his FW tank and uses the pump at all times, rather than turning off the pump and using city pressure. I do pretty much the same as well.
We refill our fresh water tank from a potable water source not associated with a dump station. And, we sanitize the water tap with a spray disinfectant (Lysol) followed by purging the tap by briefly free-flowing water from it prior to connecting to it.
Thanks, that is exactly what Susan and I were wondering. How do we get the chlorine or sanitizing agent in the tank?
Thanks in advance
mike n sue, all you would need to do is pour the sanitizing agent into your fill hose prior to filling the tank.
Or, if you have a water filter, remove the element and put the solution in the canister and re-install. When done, replace the filter element.
I'm not sure I'm on board with the simple use of a water pump to drain and refill a fresh water tank satisfies sanitizing. "Stuff" can grow and build up and adding new water doesn't mean the tank is clean. I need to learn how to use the stuff I bought and do it annually if not semi-annually depending on usage. Would you reuse the same pitcher in your fridge for years without ever washing it?
No, I was wondering where he gets the water to ‘refill” it. I suppose he refills tank and assumes that the water source he’s refilling from is safe, and it probably is. We drink only bottled water when traveling - planning to get a purifier like a Berkey.
The sanitizing procedure we use does clean the tank and all water lines, @Neal. Following the directions that come with the sanitizer/cleaner, we fill the water tank with the cleaner solution, pump water through all coach faucets, toilets, washer and ice-maker, let it sit for the recommended period of time, then drain/flush and repeat the cycle with the sanitizer. Finally, we do two fresh water purges to remove any residual, and then refill the fresh water tank.
It takes a half day to accomplish this, but we like to know that we've properly sanitized our system. And, the time between cycles is used for other coach maintenance.
And, my earlier point about not using "potable" water from taps adjacent to dump stations is simply that there is a much higher likelihood of contamination. Those in RV parks, for instance, are usually required to have periodic testing to satisfy the local health authorities. Can they also be contaminated? Of course, but it is far less likely than those next to the dump station. And, that's why we sanitize any water spigot before we use it.
