Hydralift motorcycle Carrier for Class A
skychs
RVF VIP
Glen Allen Virginia
Ventana LE 3636
Today I installed a used Hydralift motorcycle carrier on my 2015 Ventana LE. Its big. Its heavy .... but it hauls a lot of weight. In my case I will be hauling a 590 lb R1250 GSA. I still have to clean everything up, hide the hydraulic lines and get it lubed but Im very excited about all the possibilities. Installation was somewhat complicated but the PO already had the chassis mod welded to the frame. In addition to the lift you can also drag a car or another trailer behind the lift with the built in receiver. When not in use it folds up closer to the coach.
Nice job and your coach is way too clean!
The roof is one of the cleanest I’ve seen. You’ve set the standard there.
I see online that it will carry 1000 lbs. Cool.
That’s correct. The BMW comes in right at 600 Lbs so I should be good. I’m sure it will carry more but they have to set limits. The PO has CanAm Spyder on the lift.
