Hydraulic Leak
Dan and Rocki
While in New Mexico we had a hydraulic leak on our living room slide out. We have a 2015 Montana 3610 rl with a Polar package. Oil leaked into the under carriage, any suggestions on products to clean it? Thank you for your input.
When you say that it leaked into the undercarriage...do you mean into the sealed belly?
First...how much oil are we talking about? a cup or a gallon?
Second...how badly do you want it gone? Is it smelling up your trailer or causing any issue?
Reason I ask is that getting into the belly of your trailer is not easy and if you are talking about just a little oil...I would just leave it until you really had a reason to get under there.
If it's a lot of oil or it's causing an issue then start pulling the belly apart and just use some degreaser to clean everything up. If there is insulation that is oily then you will be heading to the home improvement store to get some more.
