- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
It only took 3 years and 7 months but finally my coach rides smooth and quiet. I've been struggling with some type of rubbing or some noise in the area of the right windshield A-pillar where I thought it was wire bundles bouncing around underneath. Both left and right sides I secured the wires but still had just plastic on plastic rubbing noises. I finally noticed one of the Philips screws on the bottom wallowed out the hole in the plastic so the A pillar was not secured. I used a marker to blacken a small washer and used that, the A pillar is now secure and no longer making the rubbing noises. What a relief!!!
The other odd improvement is the ride seems much better with higher tire pressures. By chart my tire pressure should be around 90 front and 75 rear. With various mods some weight increased and I've done four corner weighs and twice now it's been recommended to run higher tire pressure vs. chart numbers for sidewall life improvements. Per my last Gaffney Freightliner four corner weigh and tech recommendation I'm running 105 front and 90 rears. It seems at the higher tire pressure the tires are balanced better and offering a smoother quieter ride. While I have zero experience with tire balancing, I wonder what pressure they use when balancing a tire, if any. I also wonder if the tire runouts (roundness) is improved at higher pressure? Regardless, the ride is simply better at the current tire pressures.
A very enjoyable ride and now quiet. It took a long time to figure out and refine but what a joy this coach is to drive.
