Thank you this helps greatly!According to a 1997 Georgie Boy Owners Manual (link below; see Page 6), the 1996 chassis had a GCVWR of 18,300 pounds and a GVWR of 14,800 pounds. That would allow a maximum towing capacity of a properly loaded coach of 3,500 pounds. I know this data comes from a 1996 chassis, but I don't think the chassis changed significantly between 1994 and 1994.
Here's the link:
Good luck.
Thanks will check it out.Your Weight label should be a sticker in the wardrobe. per the manual link above page six top of page second Column.
