Ice maker water solenoid valve
RobbieBev
Trying ro winterize 2016 Fleetwood Bounder. Need to get antifreeze to ice maker. Manual says turn off ice maker water solenoid valve. Where it this located?
Built-in the ice maker the lever that controls ice level should be able to be locked in the full position.
You didn't state the type/brand of your fridge. If it's Norcold or Dometic, the solenoid is attached at the back the fridge, accessed by removing the outside panel. To turn it off, lift the bar in the freezer compartment.
The water flow solenoid is at the back of the fridge. I disconnect the water line going to it and I also disconnect the water lines feeding the in door water dispenser and the ice maker. On ours, these lines are at the front of the fridge at the bottom. Final note I do not close the water line feeding the fridge I simply disconnect it and leave it open so in the event there was any residual water in the lines it has room to expand.
