One needs to understand power management. Switch to LED lighting, and use propane for the water heater and refrigerator. So what type of equipment do you plan to use with the outlets? TV - not much power, hair dryer - lots of power, microwave - a LOT of power, Air Conditioning - a LOT of power, Coffee maker - lots of power, recharge cell phones or laptop computer - not much power.
Each piece of equipment lists the power required in watts. If it only gives amps, then multiply amps times 120 volts to get power in watts. Add all of the watts together to figure out the total needs in watts Of course, this assumes one tries to run everything at once. That is insane and an unreasonable expectation. Once you have the total watts, divide by 12 to get the number of amps from the 12-volt batteries. Multiply that by the number of hours you intend to run the item or items and that gives amp-hours. This is the required battery capacity needed in amp-hours. For normal flooded batteries or deep cycle, figure 50% discharge which means you'll need twice the amp-hours required from the batteries as one can safely only use 50% of the battery capacity without damage to the batteries. The converter size in watts should be equal to the largest load, plus about 10% minimum.
Thanks for the explanation. Just want to run a CPAP machine, and would be nice to perk some coffee. Don’t the bigger units have outlets available for use? My point being, $30 k unit dry camping and can’t use outlets. Disappointing!!
