TJ&LadyDi
RVF "Dinosaur"
Since replacing the ignition switch didn’t fix the problem of the engine not shutting off in our 2018 Mountain Aire, I’m moving to the next step. As I understand the shut-down circuit, a relay activates a solenoid that closes the fuel valve, shutting down the engine. Does anyone know the location of that relay? Is it part of the Engine Control Module (ECM)? And, if so, if the relay is bad, is it replaceable or does the ECM need to be replaced?
I have looked in the ECM and find nothing that is obviously labeled as the relay in question. And, it doesn’t appear that anything in the ECM is plug-in replaceable. Am I missing something here? Could the relay be located external to the ECM.
I guess the next step if the relay is not bad is checking/replacing the solenoid-activated fuel shutoff valve. I have yet to find the valve location, but that’s also on my to-do list.
Any help with locating the relay and/or fuel shutoff valve will be sincerely appreciated. Thanks.
