- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
On the IRV2 forum there is a discussion once again on the KIB sensors and I thought, I'd bring it over here with respects to the problem I am having. Last year I had a lot of problems with my KIB sensors on my gray and black tanks. Newmar had KIB out twice, ultimately replaced and recalibrated my sensors, as well as moved my water pump because that was affecting the levels too. Although not perfect, the sensors did pretty well for about 8 months. Sometimes it would take 24 hours to right themselves after dumping. Then I started having problems. When my gray tank levels would increase, the black tank levels would go down.
When I was at Newmar the past few weeks, I told them about my problem and that they should fix it under warranty, as it is a known problem and they knew when I left last year that they weren't 100%. Of course, they did the spiel of cleaning my tanks 1st. I told them no problem, put as many chemicals in my tanks as you want, but that is not the problem. They recalibrated my sensors and gave me the upgrade. Not even a week later since I left Newmar, I was doing a sewer rinse. When I dumped the tanks, black level is at 5%. It doesn't zero out. As I fill the black tank and it reaches 45%, it stays there for a bit and then starts going down even though I'm continuing to fill it up. I tried this several times and each time, it stopped at 45% and then goes down. I will try again with a flow meter so I can see how far I can go. I did not go to the point of hearing gurgling in the toilet because I was afraid I couldn't run fast enough to turn the water off. Someone had suggested disconnecting the power source and that might reboot the sensors. That had no impact on my sensor readings.
Thank you Red Baron for responding on the other thread.
