LED awning light strip on wall. General question about power supply.
Kleppe
I have a 2013 Coachmen 29BHDS travel trailer. I want to put up a LED strip under the metal track on the wall that the awning is attached to. Does anybody have a good suggestion where to connect to power?
With the light strip came a controller for remote control and sound control. Does not appear to be very weather resistant. Anybody installed these before and how?
In advance, thank you for any tips!
Common location now a days. Make sure you use 3M tape so it stays. Easy install would be to drill a hole high up near the end of the awning and basically run a power wire from the light strip into your RV, put plug on the inside end to run an extension cord to the closet,outlet. Otherwise your going have to have a power source inside up high where you bring the wire through to tap into with a switch.
