Limit Lithium battery charging to 80% with Victron SmartSolar
Richpatty
Wesley Chapel, NC
Ventana 4310
Freightliner
400hp
2007 CR-V
I know I should know this….but if I am parked with shore power, the solar will keep the lithium’s at 90-100% at all times. Is there a way to limit it to 80% SOC? Can you set it to a certain voltage level (i.e. 13.2v or so) to achieve this? I have a Victron SmartShunt, but I am not sure it will talk to the SmartSolar (at least for SOC).
For now, I am managing this manually, by shutting off the solar charging until the batteries get low enough to charge….but then I have to catch it before it gets to 80%. I have the magnum charging off.
Thoughts?
Rich
Well, I was hoping to stay out of this haha. My opinion, as stated in another thread on this topic, is this doesn't apply to LiFePO4 chemistry. I think it's more important for LiFePO4 batteries to keep cells balanced and that requires some discharging at times to 100% charge from what I understand. I don't think we are going to see any effects in our usage or ownership time that will benefit from the 80% charge "belief" and in fact I've been reading the benefit to iPhones has proven to be minimal such that I have mine set to charge to 100% every night and do not use Apple's battery saver whatever it's called.
Just my $.02 - it's not worth dealing with and may be incorrect for this battery chemistry. But I'm all ears and open to learning from others.
I too am waiting for others who may know more.
I had adjusted my charging settings based on trial and error to have charging stop in the 80-85% range.
But then I learned that my battery cells were not properly being equalized by doing this.
So I have reverted back to my original settings so that we hit 100% regularly.
Our batteries (Lithionics brand) are nearing 10 years old and still doing well. Have no plans to replace them anytime soon.
Thanks guys. I agree that going to 100% is something that should be done on a regular basis…but was not sure if sitting at 100% most of the time is good either…. I think if you are using your solar on a regular basis (boondocking or on a home), then just letting is go is fine. But we don’t use our RV to boondock as often as I had imagined or hoped, so anytime we are out, they sit at 100% much of the day (due to solar) and don’t drop too much below 95% overnight.
When my RV is home,it is covered and unplugged (except a trickle charger on the chassis batteries) so I usually just cut as much load off the house batteries and let them sit. I can usually get at least 30 days before they need any charging, at which time it is time to take the RV for a drive anyway (and run the generator). So maybe I am over thinking this (wouldn’t be the first time) and having the lithium’s “rest” between trips is good enough.
Thanks for the sounding board.
Rich
I’ve been plugged in at CG’s and far too many months in storage and I’m happy keeping it at 100% personally.
100%, yes 100%! This may depend on your batteries. It never depends on the brand of cccv power source.
If you find the balancing circuit is an active circuit 80% is ok, but if the balancing circuit is passive, the battery cells will never balance, ultimately causing premature failure.
In the past only top of the line BMS circuits had active balancing. I have no idea what battery manufacturers, or battery models have active balancing.
I would error on the side of caution and figure passive. That would beg for 100% charge.
Head scratch... I use AC-IN set to SOC at times with Magnum, but haven't paid attention to the charge side. It may be a way to adjust the Magnum to do what you want. You may also be able to set so parameter to switch the smartsolar mppt.
Forget SOC as a means to regulate anything. SOC is just a convenience item for users to get an approximation of where you are in actual capacity.
You'll want to use voltage as your primary guide. Generally speaking, a good charger that has a settable, user defined charge profile will have an absorption voltage setting and a float voltage setting. A good general profile would consist of an absorption voltage of 14-14.2 volts, followed by an absorption time. after the absorption phase then the chargers voltage output would fall to a float voltage of 13.5.
So the phases would be bulk phase, where the chargers simply throw as much current as they can at the batteries, In the bulk phase the voltage will slowly rise until it reaches the set absorption voltage (14.2), then hold that 14.2 volts for 15 minutes to an hour depending on bank size, during this time battery balancing is accomplished. After the absorption phase is complete the charger drops voltage to 13.5 to a lower voltage that applies less pressure on the cells. You can then sit at 13.5 for days and weeks as needed or until all charge sources, such as solar or shore power, are no longer available.
If you want a storage condition, lower voltage more to 13.3 for a midrange storage.
Lithium likes a CVCC charging pattern. Most batteries have the manufacturer recommended charging voltages printed on the label, or literature. And that recommendation will vary. Some higher end batteries have active balancing circuits built into the BMS while lower end batteries may have a passive balancing circuit.
If you don't want premature battery failure, I suggest you follow the battery manufacturers recommendation.
