What is needed to replace the lead acid batteries with 4 100a lithium batteries In a Baystar? The Newmar owners manual discourages changing from lead acid to lithium batteries.
I believe you will need to change out the BIRD to a lithium compatible one. Also, depending if you have a inverter charger or converter, you will need to change the settings or converter.
You also really need a shunt based battery monitor to properly tell your charge status. The victron smart shunt is a good choice as it’s easy to install and use.
I agree with the the above points. I also replaced my BIM, but I figured my 8 batteries could draw on the alternator. Not sure 4 batteries would. But never a bad idea to do.
