Tgicamping
- Mar 6, 2023
So, if I understand correctly, my go pro panel will change from flooded to AGM to lithium, so if I change over to the lithium batteries all I need to do is cycle the panel to say lithium??Unless your converter has provisions internally to select lithium batteries, then about 80% charge is all that can be expected. Lithium batteries operate at a slightly higher charging voltage as opposed to FLA or AGM batteries.
In our case, the converter has a small jumper that is moved to a different position between pins to change the charging profile.
Bob
There may be a couple other things that need to be for lithium as well. When we were researching new rigs and looking at the lithium option the battery isolation manager (BIM) was one of the items that was different as well.So, if I understand correctly, my go pro panel will change from flooded to AGM to lithium, so if I change over to the lithium batteries all I need to do is cycle the panel to say lithium??
I dropped in one of these and don't worry about battery issues. I have the Juice pack. My power converter is able to recognize lithium batteries. The battery name has changed but was reviewed by HoboTech. My wife and I are weekend campers and always use the grid.Can I put lithium batteries in my Wolf Pup without doing anything to the converter?
