Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
Hey everyone. So as many of you know, last year I moved to 800ah of Lithium. As part of the project, I replaced my BIM with a Li-BIM which gives the alternator a break from charging the house batteries every 20 minutes or so. This is done due to the fact that Lithium's are very hungry batteries and will basically take every amp they can get. Some say that this type of draw can over-tax an alternator, thus the need for the Li-BIM.
There is a long running thread on the "other forum" where folks are making the argument that indeed the Lithium batteries can tax an alternator, but that a Li-BIM may not help that much. This is due to the "on/off" nature of its function. It is said that when the Li-BIM cuts off the connection between the Lithium's and the alternator, that the sudden drop in power can cause some kind of "dump" on the alternator and cause issues or even damage it.
So, if this is true, some folks have suggested that you use a DC to DC converter in place of the Li-BIM, which would limit the amount of power being pulled from the alternator. But it would probably impact the ability to charge the chassis battery while on shore power as well as the Aux battery jumper function (since the BIM would be removed from the system). So I don't like that option all that much either.
My other thought is to put in a battery switch (like this: https://www.amazon.com/gp/product/B07T288VN8/?tag=rvf01-20) which I could turn off while driving, but turn it on when on shore power. The other idea someone had was to put a 125amp fuse on the line, so if the batteries call for more power than that, the fuse would blow and protect the alternator.
So, I really don't like any of the ideas....so I am tossing it out to everyone to see what your thoughts are. I know some folks have said that the length and gauge of the wire between the house batteries and alternator is not enough to push much more that 60-100 amps anyway, so this may be a moot point. But is it something I should bet my alternator on? I have a clamp meter, which I suppose I could try (I believe it even has Bluetooth), but I have not worked very hard to master its use (embarrassingly). That could give me an idea if I have anything to worry about.
Thoughts anyone?
Thanks
Rich
Thoughts anyone?
Thanks
Rich
