Rustymayes
RVF VIP
- Sep 11, 2022
- Vacaville, CA
2022 Dutch Star 4081 on FL chassis.
I posted a few months ago, that my camping neighbor had cooked his house batteries on a 25 foot trailer and stunk up the camp ground. I was worried for a minute that my batteries had cooked as I had never opened them up to check the electrolyte levels. I unstrapped the batteries and removed the 1/4 turn caps and SOB! the cells were bone dry. I sourced some distilled water and proceeded to top off the cells to within and inch of the service port. Well... fast forward to today and I decided that since my coach is plugged in 24/7/365 I better keep an eye on them. I opened the battery bay and found a mess of battery acid residue and the ensuing corrosion in the bottom of the battery rack. I surmised that I had over serviced a cell or two and the excess boiled over during normal use and charging.
I removed all of the batteries and neutralized the acid spill and will repaint the affected area. As I was removing the batteries and checking the rest of the cells I noticed that these batteries are in fact AGM batteries! I thought AGM batteries were service free and hence were sealed and of course marked as such. NOT!! These batteries have a label with AGM in the model number and another placard with several small print notices none of which say Maintenance Free or DO NOT ADD Water. They say do not disassemble and contains corrosive substances blah blah blah.
I did some digging on the web and found several articles that say that AGM batteries are Maintenance free and do not add water.
They (in Pairs) are holding 12.8 volts so I am drafting off what water that I can and will fully charge and test them before I reinstall them and try to get what life I can as other than them expelling the excess water, they are not showing symptoms of failure.
I thought I would post this in case anyone here might be tempted to add water if they checked the cell levels since the tops look like they are designed to be removed for service.
Also interested in any constructive commentary you guys in the battery world might have.
As an aside, I removed the entire battery drawer assembly to clean up under it and repaint the bay floor and was astounded to find that the mounting frame was only held in place with two bolts on the inside corners of the frame. This allows the whole drawer rack to bounce up and down as you rattle down the road. There were never any holes drilled in the bay floor to accept bolts! Might want to check yours out.
