Hi everyone, I have an electrical problem that neither Winnebago or Workhorse seem to be able to solve. I have a 2007 Winnebago Class A Sightseer (26P model). Currently the passenger front marker light is not working. This causes the right turn signal light on the instrument cluster to stay on when the lights are on and the ignition is on. The turn signal works fine when it is activated but stays on solid otherwise. I have replaced the bulb in the marker and found 11.5 volts present when it is turned on but the light will not go on. I exchanged the bulb with one from another marker and it does not work either. So, I’m hoping someone out there in Winnebago land has a solution or suggestion ‘cause I have run out of possible causes.
Thanks in advance for any ideas, solutions, or wild guesses!
Dave
Ps, it worked last week! Not so much now.
Dave
