Afternoon newbie here, I have a 2014 Coachmen Leprachaun 320BH, will crank but not start, like it is nit getting fuel? Anyone have this issue. TIA. (FRUSTRATED) Humdinger2008
Basically you only need fuel, spark and air.
Check a plug for spark,
check the air filter for blockage,
then you are left with fuel.
Fuel can have several issues, blocked filter, empty fuel tank, bad pump. If it is fuel injected, you should hear the pump cycle briefly when you turn on the key. Carbureted engines typically have a mechanical pump, no noise. So you will need to open a fuel line slightly to verify pressure.
