J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
From a temperature point of view, yes. But no other AGS functions are affected. You just can’t have the genny come on for AC or heat when you don’t have shore power….Eeek, AGS is tied to the thermostat? I didn't realize I'd lose that. Will need to contact them about this. With pets this is important.
Hello from Kevin at Micro-Air. Our thermostat is designed to perform every task your prior thermostat did -- and more! If you had an Automatic Generator Start (AGS) on your old thermostat, the Micro-Air EasyTouch RV thermostat has it too.I have had one since May of this year and I love it. My favorite feature is the ability to turn the heat up from bed via my phone app. Once its warmed up, then we get up.
It also tells you the temp inside and out. And, of course, the ability to adjust it from where ever you are. One night we were in the campground and I was with my son at the game room and DW texted me and wanted to turn the heat on and was not sure how. I was able to check it from where I was.
If there was one drawback (at least when I got one) was that it was not able to work with the AGS… but that is not a showstopper for me. I heard that they were working on it.
Otherwise it was pretty easy to install And correctly identified my three zones and the associated functions. I like it a lot more that the Dometic one that came with the RV.
And it can be programmed, but I have not used that feature.
This is a screen shot from just now.
