Cold_one
- Mar 20, 2021
- Manitoba
- Newmar as of 2021; Beaver 2012-21
- London Aire; Patriot Thunder
- 18 Lincoln Navigator; prior 13 Explorer
So, in a world where things are tried out for substantial time before buying, we may have done something different. However such was not the case as we bought a 15 London Aire 4553 without much “testing” so to speak.
The problem arises as my wife is in a wheelchair and has limited mobility. We initially thought the rear bath was doable, and she used it a number of times. However this entails me lifting her in the wheel chair up onto the rear platform; not the easiest or most convenient use. Plus some element of danger if the chair were to slip.
Consequently we are looking at her using the middle bath but the way the door is mounted/hinged does not provide enough space for entry. If removed the doorway is wide enough, not for the chair, but enough for her to get into it.
My thought is to change the mounting hinge to a regular hinge so the door opens out. The full slide has to go out for her to move around anyway (either mid or rear bath) so Newmars trick door hinge Isn’t really necessary. Yes, if it’s changed, it will affect entry if the full slide isn’t out - that shouldn’t happen to often.
Doing so will likely entail removing some outside moulding, which certainly detracts the appearance of the coach, but it may be the solution. A sliding door would be difficult and a folding door would take up too much space in the opening. Picture is door opening.
Any thoughts or comments are appreciated.
