Mike Moore
Mike Moore
Greeters to all my RV new friends!
I have a question about my 2007 Keystone Challenger panel fuse box. I have a red led light on.
There are led lights next to each fuse. They are not lite. The one that is on dosent have a fuse in the slot next to it like the others.
When i pull any other fuses out a red light next to fuse comes on.
Could this be a low battery warning as my lights are not brite when i turn shore pour off?
Thanks Mike
on my Forester the red light came on to indicate Tharp the fuse was blown. This sounds like the case on yours, as, the slot without the fuse has the red light on, and the light comes on when you pull one. Nice feature.
I wish my BayStar had that feature
Yep, I think what you are seeing is a open fuse indicator. The lack of a fuse is the same as a blown fuse; an open circuit, so the red light comes on with no fuse inserted. Try inserting a fuse with the listed amperage or less in the open position and see if the red light goes out. If that works, and if the fact that the red light is on without a fuse concerns you, install a token 1A fuse.
