northcoastagility
- Mar 23, 2022
Hi all - I have a 2012 Monaco Monclair 29pbt and the rear slide out in the bedroom is stuck out. I think there is a larger issue with power (the lights are dim and flicker - 12V and the 12V also runs the slides). So, I cannot get the back slide in and I cannot locate the slide motor. I have looked under the bed and only found the fresh water tank and water pump motor. from the outside you can only see 2 cables - no ratchet mechanism or external place to engage a manual override. So, help! Any suggestions? Do I need to pull back the winterizing underneath to find the motor or a work around? I need to get the slide in so I can take it to the repair shop to figure out the electrical..... sigh. Thanks all.
EDIT: Okay, I found the motor - it is up behind the trim above the bed. So, I got that figured out (it doesn't help that Monaco Montclair's didn't develop up schematics) and unplugged the electric, and then racheted in the slide. So, that's good. Now to get it to the mechanics to figure out what all the weird electrical stuff is that is going on.
