Question Motorhome four wheel position weight
Not open for further replies.
Florida
CanyonStar
39' 11"
Demco KarKaddy 460SS and VW Passat
We have had the Newmar weighed many times at CAT scales and leave some fudge factor for side to side differences when setting tire pressures as I know they exist on this Motorhome. We've had the Newmar all four wheel position weighed a couple of times but have made significant changes since the last time. How do you get all four wheel positions weighed other than a Rally or Safety Seminar?
Has anyone ever used a CAT scale to get a weight side to side? The one I use at the beginning of our trips does not have enough room to weigh just one half of the rig due to metal barricades to keep the rig aligned with the scale.
No Where In Particular
Dutch Star 4369
43’ 9”
2016 Colorado
Yes
I Believe most CAT scales are unable to do 4 corner weights for reason you state. If anyone one knows otherwise please advise. I recently saw scale in AZ where it specifically stated not allowed
Orinda, CA
2015 Jeep Trailhawk
My understanding CAT does not allow four corner weighing.
WA, MT or somewhere else!
Mountain Aire 4047
40'
2014 Honda CR-V
Here's a possible alternative; highway weigh stations. In many states, when the weigh stations are not in use by the DOT enforcement folks, the scales are left turned on. It is pretty easy to put one set of wheels on the scale and the other on the apron. Once you get your weight(s), circle around and repeat with the other set of wheels on the scale.
Since most highway weigh stations have multiple scale pads, with a little careful placement, you can also get corner weights.
Florida
CanyonStar
39' 11"
If you are a member of Escapees there are some additional choices
Fredericksburg, VA
KSDP 3910
I went to a local moving company and used their scales. They didn’t even charge me for it. I was surprised at that.
Sarasota, FL
London Aire
40'
2008 Jeep GC Overland
I went to a local wholesale landscaping company. They have a big drive on scale, since they charge by the pound for everything they sell. They charged me $7 and I could get all combinations of axles - each corner, each axle and total. Just plan to go when they are not busy, I went around 10AM.
