New member
Gingerly
Dayton, Ohio
Itasca
Impulse
29t
I bought a 2008 Itasca Impulse last November. I’ve had it out about 8 times. It is usually just me occasionally a friend but definitely a learning curve. I used it to visit my granddaughter and parked behind her house and plugged in to the house power. It was very hot so I switched to the generator to run the AC. I was there for about 5 days and all was going great till the last night. The condensation from the AC backed up and started to drip slowly in the back bedroom. It was late at night and it was raining so I wasn’t sure what it was at first. The next day the AC didn’t work and my gas went down to 1/4 tank. Was the AC running off the gas in my tank or propane? Is it possible the switch on the fridge if in auto mode is running out the gas?
I can only speak to my coach but the generator will run until 1/4 tank of diesel so as not to strand you. It sounds like that's your case as well. As to the dripping in the bedroom, that shouldn't be happening, obviously a leak somewhere or a gasket under the AC is not installed properly or deteriorated.
