New Member
Vancouver, WA
Rexall
Airbus
36'
Chevy truck or trailer with 2 harleys
Hello everyone. I hope everyone is staying safe during these trying times. My wife and I bought our motor home about 10 years ago. We haven't put a lot of miles on it. But, camp in it often. I have been doing some upgrades and could really use some help. I am replacing the power converter from a Magnetek to a Power Max. The problem I am having is the wiring. I have watched many You Tube videos. But have not found one to answer my question. Wiring up the left side the 110 volt is a no brainer. White wire to neutral bus with all the other white wires. The black wire to the breaker. and ground to the ground bus. But, the 12 volt side is what I cant figure out. The new converter has the red positive and black negative coming out the back. The 12 volt fuse panel in the motor home has a red, a white, and a blue wire. I have tried different combinations. Have had power to both sides of the fuses. But, nothing 12 volt in the couch will work. Finally after messing with it for many hours, I put the old one back in and powered all 12 volt things. I'm wanting to replace it because it doesn't charge the batteries as I think it should. And it doesn't put a full 12 volts to run the furnace. It is a 1995 Rexall Airbus. If some one could tell me how to wire the 12 volt side, I would be very thankful. Thank you. Jim
Welcome to RVForums @YZer. I'm sure some of the electrical experts in the house can help you out. Welcome aboard.
Vancouver, WA
Rexall
Airbus
36'
Thank you Neal.
WA, MT or somewhere else!
Mountain Aire 4047
40'
2014 Honda CR-V
Welcome to RVF, @YZer; glad to have you here with us. There should be someone along soon with some electrical expertise.
Vancouver, WA
Rexall
Airbus
36'
Thank you TJ & LadyDi.
