No connection between battery disconnect and lithium batteries
Carol W
I have a Roadtrek Zion 2020. Was de-winterizing it today, and discovered my battery disconnect switch and lithium batteries were not working. I heard the double click when I pressed the battery disconnect button, briefly saw the wattage light indicating the voltage available, , and the blue battery lights came on . Within seconds the wattage indicator turned off and I couldn't turn anything on in the van----no fridge, no water pressure, no lights, etc.
I'm not sure what the problem is----would appreciate any thoughts. Do I need new batteries, a new bd switch, something els?
Thanks,
Carol
Most likely your lithium have gone into sleep mode.
Try putting a 12v power source direct to the battery and it should wake it up.
A battery charger, jumper cables, 12v dc power supply. Any of these options will work. It usually only needs a few seconds to wake up.
