Question No propane flowing
The Accountsnt
Good evening. I am new to forums for forgive me if I am rambling. We have a 2019 Coachman Beyond 22C that’s new to us. Only used 2 weekends so far. Has a built in propane tank that’s full and switch is on but getting no propane to stove and water heater. Is there a potential simple fix because we can’t get it in for service before our 2 week trip to Vancouver Island.
May sure the battery switch is on. The appliances will need power to ignite the gas. Other than that it could be the regulator. If you can’t get it I recommend calling a mobile tech. Someone can get to it before your trip. Good luck and welcome to the group.
Seems obvious but this can be overlooked. Make sure the valve at the tank is turned one.
Thanks - so mobile techs are okay to use
Make sure the propane/co2 detector is turned on
Thanks - so mobile techs are okay to use - any good ones out there
Just research your area. Yes we have had good luck at home with one last year just before a trip. Good luck on the road as well, a couple of times over the years.
Had it happen to us a couple times in our Forester.
Turned out that if I opened the valve too quickly on the tank it would trip the flow switch and stoop all flow.
Easy to check by closing the valve, open slowly, then check things again.
May not be it but worth a shot.
