TJ&LadyDi
RVF "Dinosaur"
We have now had two instances where turning the key off...and even removing it...wouldn’t shut the engine off. Cycling the key 10-15 times finally shut it down. Tried several restarts and it works...right now.
Bad ignition switch or relay? Called Newmar and the said “call Spartan.” Called Spartan and they had no idea. They said call a Spartan shop in Missoula. That shop said “too busy to look at it.
If it isn’t one thing, it is another. Anyone else had this happen? Cause? Fix?
