- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I have ITR OASIS in my Newmar Ventana but this discussion may apply to other systems of the same setup with electric heat elements and a diesel heat elements. In my OASIS CH-50M the electric elements are 5K BTU each (2 elements) and a 50K BTU diesel burner. My question for the gang here is when do you use which? This is also weather dependent as this is very different in summer heat vs. winter so lets focus on cold climates where we need house heat and hot water.
It seems to me that the electric burners can heat the house to an extent and I have no problems with electric only heat when in storage for winterization. I'm in Tucson and the nights are cold near freezing. As others I prefer not to burn diesel when I don't have to but the heating is much more efficient with the 50K BTU backed heating (diesel burner) so the fans run less, etc. Last night I was on electric heat only and I'm not sure it did so great possibly struggling to maintain my 70 deg setpoint (which is lower than most I assume, others probably like it warmer). I may have been cold because of the lower setpoint but the discussion still remains. What are your rules of thumb as to when you use diesel burner vs. electric heat for HEATING.
As for water, in the winter I always use diesel burner. I'll turn it on at least 10 prior to shower time such as when I take fido to do her business. Electric elements can work fine I just prefer unlimited very hot water. I probably need to test this again as I've spent far too much time not knowing that AC 2 wasn't working and recently finally fixed this saga by replacing the failed relay.
When do you use Electric vs. Burner in cold climate ops?
