Outside built in tv replacement
Rfstuart
We have a 2015 Thor Outlaw 37LS with a 32” tv built into an enclosure in the wall with a hinged lockable cover. The tv has failed and I am looking for a replacement. The problem is that the enclosure is only 2” deep. The current tv is a Continu.us ct3200 which is no longer made. Most tvs are now around 3”-3-1/2” deep. Has anyone had to change out one of these built in sets and if so, what brand/model did you find to fit?Thanks
The only brand that I see advertised that will fit as I have the same problem is the Samsung Q60 series tv's that are a little over one inch thick. The price doubles for these particular TV's.
I was looking at the enclosure and noticed that If I removed the fasteners on the can I could install either in hardwood or thin steel square tubing a spacer ring that would make the space deeper. I saw nothing obstructing the movement of the can. I would have to move the pins on the lift arms onto what ever I space it out with.
