Question Phaeton Slide
Wolverine33
Have a Phaeton 2008 …….. lost power on passenger side front slide …….. all went out at same time . I’m assuming there is a separate breaker or fuse for those . Any idea where that would be located ?
Not familiar with your unit, but should be some breakers/fuses in or near where your power cord/transfer switch is located, will probably also be a breaker or fuse on the slide control board located elsewhere. You may be able to google search for a wiring diagram for your specific coach model to help you locate both.
