- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
EMPTY IT! To make your heavy water filled water softener tank easier to manage such as stowing or removing from the coach, unscrew the top where you put the salt in for regens and tip the tank over and the water will come out. Be careful not to empty too much or tip too far (close to 90 degrees) as the resin (brown) will come out.
For anyone going to areas with hard water I highly recommend the On The Go OTG4-VM-DBLSOFT Portable Compact Double Standard 16,000 Grain Water Softener
https://www.amazon.com/dp/B085Q2LBJV/?tag=rvf01-20
You would be surprised of places that have hard water. Even on the east coast I was caught off guard on a beach location that had hard water. What I do out west is prior to hooking up the water I sample the water into a cup and test it with a test strip and that tells me whether or not I need to use the water softener.
