Orrin
- Jun 18, 2021
- Fitchburg, WI
- Holiday Rambler
- Ambassador
- Varies, I use a Demco SS Kar Kaddy
2XSimple Green
We had that buildup issue years ago, with our old Winnebago….finally had to have it professionally serviced, on an emergency basis, when the engine overheated while we were on a trip - EXTREMELY expensive (several thousand dollars) - not sure that we weren’t taken advantage of.Thanks @Neal, mine is really gunked up. I have to clean out 18 years of slobber tube oil and road grime. I am thinking of using CRC Brake Clean and then Simple Green purple, and then flush with a garden hose with hot water. Mine is rear radiator, CAC, and transmission cooler. Access is a problem with out removing the R, CAC, and the TC. I don't have the ability to do that safely.
