Question Redhawk main entry door deadbolt jammed
weathermantim
Riverhead NY
Jayco
Redhawk
Ford
My 2021 29XK main door deadbolt jammed in the closed position. It happened suddenly. I have tried lube, pulling and pushing etc with no luck. The key will not even go all the way into the lock. The inside plastic latch will not budge open. Since the screen door is also closed, I do not even know how to disassemble the latch assembly, since I can't get to the one or two screws as the screen door is in the way. Any suggestions? Thanks!
