2cmprs
- Sep 5, 2020
- Chesapeake Virginia
- Grand Design
- Transcend Explor 221RB
I am assuming you are talking about a 2/3 way reefer and vent is located on sidewall of the RV. Putting a screen on inside of vent would be ok, just make sure it doesn’t contact any of the components
Yes. Found wasp nest in both upper and lower section.I don't think window screen material will significantly reduce air flow; at least not enough to create venting issues. If you have a choice, use the coarsest screen available that is compatible with keeping out the bugs you are concerned about. In our case, Yellow Jackets are the primary critter of concern, so a coarse screen would work fine.
