Renegard Vienna Empty Weight
harlanwald
I am considering purchasing a 2024 Renegade Vienna 25TBC.
Since the GVWR is only 11,030 lbs. I am concerned about the cargo carrying capacity.
I don't want to exceed the GVWR or the axle weight limits, the GAWR's.
Does anyone know the typical actual empty weight of the 2024 Renegade Vienna 25TBC?
And does this include full diesel fuel and full propane? And batteries?
If someone has weighed the vehicle, could you please post the information regarding the weights and what was in the vehicle as to fuel, propane, fluids and battery.
I understand the 2026 model uses the Mercedes 4500 chassis which has a higher GVWR so information regarding a 2026 model will not be helpful..
Am I overthinking this? I just don't want to have handling problems or tire or suspension problems as a result of overloading.
Thank you.
