- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
This is a follow on modification to the prior mod:
The headlamp assemblies that work in the Newmar Ventana (2017) are the same as for a Dodge Nitro G2:
I drove an hour at night to get to my current campground a week ago and I had to drive with the brights on to get satisfactory lighting. As we all know, first we don't drive RV's at night, second, RV headlights suck! Even with the brights on cars didn't care as it wasn't too bright for oncoming traffic and was perfect for my driving. But I knew this wasn't right and there had to be a better option. I already changed the headlamp assemblies so I researched putting LED lights in these assemblies for an even better upgrade. I learned that this headlamp assembly takes H1 and H7 bulbs for normal and brights so I did some Amazon research and decided on the two items below:
Yesterday I started the process of pulling the bulbs out and putting these LED lights in and it wasn't as easy as I had hoped - LIKE ALWAYS!!! There is a cover plate on the back of the bulbs that seals them in, not sure why, but there is. I gave up and googled the lights and realized there has to be a screw holding this cover plate on so today I went back to give it another try. Long story short I had to pull out the headlamps completely to change the bulbs. There are 4 or 5 screws holding this cover panel on the back side of the bulbs, which of course I left off when done as I wanted the LED light cooling fans to have breathing room to keep things cool. I learned how the retaining clips worked and got the old bulbs out, they were simple halogen bulbs, and put the new LED assemblies in which worked perfectly.
For the normal lights I had to cut the wires and put female spade connectors on the coach side so the LED light wiring could plug into the two wires. Verified and it worked. The brights worked with the stock plug, I just had to unplug and rotate it to get the polarity right and all checked good. Headlamps reinstalled, of course kicking myself for getting myself into these crazy situations but in the end the difference is HUGE!!!
Before I had yellowish lighting out front, now it's bright white lights. I will have to re-aim these but as they are right now they look great. I finally tested them after dark and I'm sure the pictures below don't do it justice but I'm thrilled with the lighting I have now.
Normal:
Brights:
MOD - Replacing Headlamp Assemblies in a 2017 Newmar Ventana Motorhome
Yesterday I received Anzo USA 111144 Dodge Nitro G2 Projector Halo Chrome Clear Amber Headlight Assembly that someone else found somewhere and I had it saved to my cart for a long time. They are Dodge Nitro headlamps which apparently and seemingly is what is used in my 2017 Newmar Ventana. I...
rvforums.com
Normal:
Brights:
