Rubber Roof recoating
easterdr48
Keystone
Outback
Tow
I got on 2010 travel trailer TDPM rubber rv roof and needs to have new sealant rolled over it. What is best product to use in 5 gallon bucket.. So many products to choose from I plan on doing the work myself. Need another 10 yrs of RVing with my unit. Thanks for any recommendations.
Don't think you can do any better than Henry's tropi-coat 100% silicone roof coat. The product according to their website is formulated with RV rubber roofs in mind. You won't be unhappy with the warranty either.
I seen this product online. Thanks for replying to me.
I will attest to the quality! Have used it on 3 roofs, and painted a plywood slide in camper that went through a tornado and was totally dry when I was able to inspect it. They use humidity as it's catalyst, so won't effect your roof.
Here’s what I used. Helps with the heat too.
Thanks
It’s been on for 2 1/2 years now. No issues. Just keep it cleaned.
I thinking about doing the roof in June in southeastern VA. Humidity shouldn't be an problem. Thanks for reply. How often need to repeat process on rv roof?
Henry 100% silicone will likely outlast your RV.
I was going to get started on next week but so much rain in forecast. I thinking about waiting until late Sept/Oct to applied Henry Tropical Cool Silicone 100% coating onto RV TPDM roof. What should I use around vents chalking Henry Prep 884 or Dicor Lap sealant? I just clean roof next week with Dawn detergent/ hot water mixed. Thanks for advice.
I use Henry's roof seal, yes tropi-coat.
I did the same as Kevin.
I finished up with re-coating my 2010 Keystone Outback travel trailer roof with HENRY TROPICAL-COOL 100% SILICONE rubber coating and was amazed at finish job. Roof stays so much cooler and white. I would recommend this product to use and add years to life of TPDM roof.
