- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
Thanks for taking time to help. I checked it also and didn't see anything there, but will post photo in case something jumps out at you. No hurry. It's raining again and I'll be at Newmar on Sunday.It's not there. Check the rear door side with chassis battery...it's behind the round cover and should be labeled too. My coach is 2 hours away so I am not much help
Soooo I’ve just learned that when the lights are on, only the rear running lights are lit. The front ones light up when you signal. Always learning something.
EDIT: FYI, I may be using incorrect terminology. Just been informed that they may be called marker lights. In any case, they are the orange ones on the sides of the coach.
@ARD ... I also noticed something different on our new coach that our other ones did not do. By the passenger seat there is a switch labeled "PATIO" that turns on the outside door light and the stairwell lights ... but on this coach it also turns on a few of the running/marker lights on the coach. Not sure I like that feature as it looks like I left them on accidently when we want to leave the door light on when we go out at night.Soooo I’ve just learned that when the lights are on, only the rear running lights are lit. The front ones light up when you signal. Always learning something.
My patio light turns on patio light and handle bar, possibly stairs (I don’t know because I opened the door and the lights automatically go on. ), but no marker lights.Anybody else's do that??
