Sounds like you may be smelling leaking propane gas. It smells like garbage. Shut your propane tanks off and see ft it goes away.I have cleaned and thrown away everything in freezer and frig. It still smells rotten. Any suggestions on what causing?
Thank you for the reply but All that was done. Thhere is obviously something going on to cause the smell. The smell seems to be freezer area only. . I need suggestions on where to start to fix that issue.Did you use a disinfectant cleaner like PineSol, Lysol or similar?
Put an open box of baking soda in there.
Thank youSounds like you may be smelling leaking propane gas. It smells like garbage. Shut your propane tanks off and see ft it goes away.
Thank youHad the same thing...bought these and within a week or so, odor was gone. Worked for me...maybe it'll work for you. I leave one in all the time now...no problems since.
Just ordered, thank you againThank you
Frig running on electrical. Thank you for reply thoughThank you for the reply but All that was done. Thhere is obviously something going on to cause the smell. The smell seems to be freezer area only. . I need suggestions on where to start to fix that issue.
Thank you
using only electricalThank you for the reply but All that was done. Thhere is obviously something going on to cause the smell. The smell seems to be freezer area only. . I need suggestions on where to start to fix that issue.
Thank you
