- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
A Mobile Must Have video popped up in my YouTube feed and he referenced a comparison chart on their web site so I was curious and took a look. I dread the question "which roof antenna do you recommend" as this is a very tough question. I've used many, MANY antennas. I'm very pleased with the cellular performance of my Parsec Husky's I have now and have no intention of switching. Wi-Fi isn't great but neither is the location for Wi-Fi below the roof, inside the coach as expected. Anyways, on this web page, half way down is the antenna comparison reference which links to the PDF below.
One note: I watched a video on aircraft construction recently on using a ground plane with a component (elt) and the builder mentioned that in order for a ground plane to work the coax connection had to be on the other side of the ground plane. Many of us seem to think just mounting the antenna on a piece of metal is a ground plane. If this aircraft builders tip is true, which came from the ELT manufacturer, then we're doing it wrong. The antenna/coax connection has to go through the ground plane so the coax connection is made on the other side of the plane per this info. I haven't researched it as my antenna does not require a ground plane but for those that think you're creating one you may be doing one that's null and void for ground plane effectiveness if this is true.
