RV Washer problem
Welcome to RVForums @Brewha. It sounds like you need to contact the dealer or Splendide. Make sure the obvious first such as water supply is on (city water connection or water pump on).
Thank you. Water is on and ran a small load of laundry. Stopped during rinse cycle and started flashing lights. Took clothes out and drained water using a shop vac. Checked pump and then ran washer without clothes and it cycled through fine. Put small load in again and ran it - stopped again during rinse cycle with flashing lights!
@Neal may have posted on this before. The switch that tells the machine the door is closed may be faulty or misaligned. Use a screwdriver to push the switch in. does it click? Try an empty cycle and when it stops for rinse cycle try tripping the switch and see if it starts. if it does adjust switch.
