Sanitize/fill fresh water
Just purchased a used (two year old) TT and want to sanitize the fresh water tank and system before using.
I understand the bleach ratio, but what water do you use? We are getting it cleaned out at home, so can we use standard outside spigot and hose water? Or do we need to take the TT to a potable water filling station and fill the tank there, let it sit overnight, then go back and rinse it through from the potable water station?
WA, MT or somewhere else!
Mountain Aire 4047
40'
2014 Honda CR-V
Assuming that your "outside spigot" is on the same supply as your house tap water, just use it. The chlorine bleach will kill anything in the water and anything residing in the tank and lines.
Since your new TT may have been sitting a while before you brought it home, be sure to circulate the chlorine bleach solution through all of the water lines, including any toilet flush, ice maker, washer and other systems. Let it sit for four hours or so, and then drain/rinse several times to remove the residual chlorine taste.
Welcome to RVForums @J2999. Here is a thread that may interest you. I bought the stuff referenced in post #6 but haven't used it yet.
Thank you so much for the recommendations. Very glad to hear that. Do you guys drink from your fresh tank or bring bottled/gallon water?
I drink from the city water line directly that bypasses my tank but is filtered by the dual coach filter system (sediment and carbon) and I also drink from the fresh tank as well which is also filtered.
Mountain Aire 4047
40'
2014 Honda CR-V
A belated welcome to RVF, @J2999; I got carried away with providing a response to your question and failed to extend a welcoming hand. Sorry. Glad to have you join us.
I didn't want to complicate the answer to your question regarding "bleach," so just proceeded on that track. However, since @Neal raised the question of alternatives. This is what I use.
https://www.amazon.com/dp/B001TIV1KA/?tag=rvf01-20
Any of these thing will do the job, they just do it a little differently. Chlorine bleach is a tried-and-true method and the only slight downside is that it can leave a chlorine taste residual if you don't fully rinse every line and the tank itself.
Thank you for the warm welcomes! Happy to be part of this community!
On a side note to the above, is it ok to fill the fresh water tank from a house outside spigot using a clean hose? I’d rather have some water on board prior to heading out and would just like to fill up at home.
Mountain Aire 4047
40'
2014 Honda CR-V
You are going to need a dedicated drinking water supply hose for your RV, so may as well get one now. You should get one for RV potable water use rather than just a garden hose. Any local RV store, Walmart, etc. will have them or you can get them online via Amazon, et al.
I mark my drinking water supply hoses with a band of green electrical tape at each end (near the connector) and use that hose ONLY for drinking water. I carry an additional hose in the RV (marked with a red band at each end) for use in washing the rig, flushing the black tank, etc.
As for filling from the house tap, that should be fine.
If my fresh sits for a while then I will drain it and refill it and in that process I may put 1/3rd in, drain again, then refill. Never hurts to be careful and keep your fresh water clean. Whether house or campground spigot I always run it for a bit first to purge the rust and whatever crawled in there first then attach the hose.
Fremont, California
Dutch Star 4018
40’
Jeep Wrangler Sahara
And always sanitize the water spigot pryor to attaching the drinking water hose. If you have ever watched some of the habits of other rvers while unhooking their wet bay you might not like what you see 😝. I use a quaternary ammonia solution for sanitizing the hookups as it is way more stable than diluted bleach which degrades quickly.
Great advice all. I was thinking the same thing about the hookup at the site, people are nasty.
Went ahead and got some white fresh water hoses from Walmart, made a bleach mixture, poured it in then filled up the tank. Bleach sprayed the house outside spigot first, too.
I’ll flush it through a few times after four-ish hours and hopefully should be good to go!
Fredericksburg, VA
Kountry Star 3910
Ford Taurus
Ain’t THAT the truth!
Fremont, California
Dutch Star 4018
40’
@J&JD
Can you share a recipe if homemade?
Quaternary Ammonium disinfectant/sanitizers are used extensively in the food industry as no rinse sanitizers for all food contact surfaces at 200ppm. They are also used in bars to sanitize glasses. Here is an example:
The cool thing about them is that they are extremely stable so you can dilute them in a squirt bottle and they will sustain their disinfectant qualities for long periods. And this product, for example, can be diluted at 1oz/4gal to make 500+ gallons of sanitizer from one gallon.
I’m talking surfaces such as any external hard surface Such as water faucets, hose fittings, hands etc where you can spray and not rinse. Not to be used as an internal tank sanitizer as it foams and would be difficult to remove from inside a tank.
