Shower drain leak
Acey Deucy
Winnebago
Ultimate Freedom
40’
Our 2000 Winnie Ultimate Freedom leaks drain water under the coach. Can I repair myself?
Depends on what is leaking. Crawl under it with a flashlight and take a look. Maybe something is just loose or needs some Teflon tape on a joint.
Mine had this, the connection under the shower drain pan was loose.
Just a heads up, if the drain connection doesn't appear to leak, you might need to check the tank vent connection.
Been there done that. it won't seem to leak unless it has good amount in the tank and is being driven. ( sloshes around)
They don't exactly use schedule 80 pvc when they build RVs.
DB
