Shower Drain wierdness
oediehl
A question regarding our 2018 Allegro RED 37ba:
The shower drain wasn't draining well, so I removed the upper perforated cover and tried the baking soda/white vinegar/hot water flush. If anything it got worse. So I thought I'd try the old-school toilet plunger tactic (both dump valves were open through all of this). That didn't help, and it appeared that maybe there's been a bit of reverse suction with the plunger, because I saw something in the drain pipe that I hadn't seen before. I thought maybe it was some obstruction that had somehow gotten into the drain, and so I got some needle nose pliers to try to extract it. It's some kind of rubber sheathing, it appears, and it doesn't want to come all the way out. What am I dealing with here?
I'd never heard of a hepvo valve. Fortunately, mine looks reasonably accessible. From watching youtube videos, it looks like mine was installed upside down. Maybe that's why it wasn't draining well
Did you have to remove anything supporting the pan underneath to get to that?
I am thinking the same as you.
There should be some support under that shower pan.
I removed no support, but it is a molded shower, with support around the edges. Hmmm. I'll have to consider that. Sounds like a good question. What kind of support would you have expected?
In a house we would put a mortar bed. In an rv you could do spray foam. Do not go too crazy as it expands. I would also wait until I know that shower drain is not leaking. You do not have to fill it in solid, you can do random sections
Looks like someone got carried away with the Rectorseal. Half a pint can on the floor. The exact same Hepvo will save a lot of headache, gloves too, that fiberglass will take some hide off.
While your at is replace the rusted drain and save on future problems.
Thanks gents, I appreciate the advice. I'm leery about that connection of the hepvo to the black drain pipe, with all the goo involved. Hope that's not a problem
It's PVC and ABS so no pipe dope is ordinarily necessary, but it doesn't hurt. That looks like Rectorseal White, which is safe for ABS and PVC.
I didn't have room to get a tool on the fittings, but it turned out I could take it all apart by hand. The valve wasn't damaged, it was just that my plunger had sucked the rubbery sleeve out backwards. I pushed it back in and it looked fine, drained fine in the sink, and since I wasn't finding what I was sure was the exact same replacement part online, I dug out some Oatley white pipe sealer and reinstalled it (rightside up, this time). It seems to be draining fine now, (I guess a Hepvo is a little slow to drain the last little bit of water?), and there are no leaks. While I was down there I realized that the shower pan is sitting on a plywood platform, with a maybe 8-10" square cut in the center for the drain (hard to see with all that rough fiberglass work on the bottom, but if you look close you can kinda see it in my pic above), so I don't see a need to install more support. Yay!
