- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
My RV internet setup has been through numerous iterations starting out with having Newmar run an ethernet from the over driver's seat AV box to the dinette so I could put a mid-coach wifi router in (Netgear R9000) which also acted as a bridge (switch) to connect an ethernet to the bedroom wally box for Dish. At that time I was using a WiFi ranger and the wifi within that unit even in the AV box was sufficient but I wanted more network management control vs. the limited capabilities of the WiFi ranger AC unit. Over time the WiFi ranger found it's way into the garbage can and was peacefully removed from my life replaced with a superior Pepwave MAX BR1 MK2 unit which I still use and love, along it's twin a MAX BR1 MINI sitting next to her. The mid-coach wifi evolved to a Netgear Orbi mesh system putting one under the dinette and another in the basement and running ethernet to the Victron GX for better Internet connectivity with that. That later evolved into the 2nd mesh antenna going on the back wall under the kitchen sink, no wait, it went to the back wall under the bed and then to the back wall behind the sink for patio signal.
The pepwave wifi was sufficient but I needed this ethernet bridge to get from dinette to bedroom so the Orbi remained...until yesterday. I've been having problems with WiFi shutting down since I've been broadcasting RVFORUMS.COM as my SSID for a year now and I think the Orbi and Pepwave WiFi networks being so close were hating each other. And when I rebooted the Pepwave the Orbi would go offline so I had to power cycle it. Yes, this was all an overcomplicated mess!
Realizing Orbi's have good resale as I recently bought more satellites for my house, they aren't cheap, I figured it's time to yank this thing and simplify my life and improve network reliability in my coach. I decided to use the Pepwave WiFi (2.4/5 GHz) exclusively but my front of roof mounted panorama 5-in-1 wasn't doing so great inside the coach. I installed the rabbit ears only on the WiFi side and left the cellular connections to the roof panorama antenna and my WiFi inside the coach dramatically improved. Literally 4 hours later after getting all the devices switched over (TV's, GPS, Alexas, Temp Sensors, Air Oasis, Air Fryer, computers, tablets, phone, weather station, oh my!!!!) and the network tweaked for my on board NAS (which required me to bring the Orbi back online to get its IP changed)...WAKE UP, I'm typing! You get it, it was complex, complicated etc.
Since you've read this far here is my synopsis. The roof mounted WiFi antenna isn't such a good idea when 99% of the Internet ops are inside. Even around the coach within 50ft if not more are still fine. Moral is, the pepwave rabbit ear antennas for WiFi are very powerful (of course the box itself is the power) and in the end worked out best. Now I do have a pair of Omni antennas on the roof mid coach that are begging me to test but I'm going to leave GREAT alone. For the first time!
Keep it simple is the lesson learned yet again! My first 24 hours of RV trips is always like this which is why I do an interim stop before my planned destination. Put stuff away, reconfigure, cleanup, etc.
