My sink is bubbling and the water takes a bit to goes down. We cleaned most of the pipes but it didn't help much. We ran water through the vent pipe. Put dish soap in the drain. I don't know what to do. I sure hope someone can help.
Thank you
Suzz
Ps. I'm not sure if I am doing this right.
I always use drain strainers! Bathrooms hair mixed with soap are the biggest problem. Kitchen? Well anything can catch up in the drain. But soap doesn't come into play very often.
I use a plunger! If buildup of gunk is present, it is usually limited to the p traps, so an easy fix.
