Happy Camper Vintage
- Aug 14, 2020
Keep in mind that the inverter will draw power and generally the larger the inverter, the larger the draw. When you're calculating battery reserves, it can be frustrating to see a bunch of power going nowhere except to have the inverter sitting around on standby.I guess I haven't figured out enough about solar yet to know if I need a 12v specific fridge or a more expensive inverter for a cheaper fridge. I just replaced the converter and got 2 6v Crown AGMs to start. Would like to be able to run on solar as necessary when boondocking or possibly full time down the road. This one in particular that I'm putting solar on will need to pull quite a load. The other campers are smaller.
Hi Jim,Keep in mind that the inverter will draw power and generally the larger the inverter, the larger the draw. When you're calculating battery reserves, it can be frustrating to see a bunch of power going nowhere except to have the inverter sitting around on standby.
I mention it only for consideration when sizing the battery bank. I don't know what model battery she purchased, but if (for example) the 2 batteries in series provides her with 225 amps, and she adheres to the 50% discharge limit, she will have approx 115 amps to draw from.Your comment is true for older inverters and cheap new ones. The new ones that use a FM frequency to form the sine wave use a very low amount of energy at standby. My inverter is a 3000 watt inverter and draws less than 1/2 amp on standby (6 watts). Unless I am welding or running my table saw the transformer and switching bridge hardly gets warm enough to start the fan. we know that heat is wasted energy.
I got you. I only wanted to give the upside as well to a complete system. To point out Your example even a modest panel will add more than the inverter will waste in any given day, even if the sun don't shine. Remember also she wants to use electric fridge and will have to add power to the bank just to make it through. No matter what type she uses.I mention it only for consideration when sizing the battery bank. I don't know what model battery she purchased, but if (for example) the 2 batteries in series provides her with 225 amps, and she adheres to the 50% discharge limit, she will have approx 115 amps to draw from.
At 1/2 amp draw from the inverter, she'll loose 12-15 amps a day. A 3-day camp trip at 15amp a day = 45Amps, or almost 40% of her storage.
On my last RV, I installed a 2,500 watt, Ames inverter that drew 4+amps an hour and it hurt to add that all up over a 3 day camp trip. Yes, it had a sleep mode that only pulled about 1/2 amp, but that wasn't enough power to keep the clock on the microwave running.
As I said, I mention it only because it should be included when sizing the battery bank. The type of appliances she chooses to run and the number of items she uses, and the amount of time the inverter will be on, will all have to be factored in when choosing the best solution.
